Can Gas Treatment Save Half Tank of Fuel?
Jacalore
Re: Can Gas Treatment Save Half Tank of Fuel?
No elephants around here, so it must work!
Jacalore
The ethanol doesn't mess with the carb?
BonairII
Run a can of seafoam in your fuel once a year...you'll be fine. Ethanol is hard on rubber hoses etc, but nowadays new fuel line etc is ethanol resistant.
oldjeep
No. We've had nothing but E10 around here for 20+ years. You can get non-ethanol in a few places but 90% of the boats here are just running pump gas. If you have 25 year old fuel lines, then you might have problems. Ethanol cleans your fuel system out quick, so if you have a bunch of crap in your fuel system then plan on replacing the filter a couple times.
Jacalore
Hmmm... Okay, makes sense. Thanks.
GoFastr
Gas sitting only since last August should be fine. Based on your description there's more to the story like either that particular batch of fuel has been in there 3-4 years, or there are other contributing issues.
Go in thru the fuel sender hole and syphon out using a length of clear 3/8" tube hose from HD or Lowes so you can see the color and any anomalies coming out into the container. Containers need to be lower than the tank to work. If it appears to be clear or clean, then for some reason your filter disintegrated. But again why? If you syphon it all out (if you can deal with it after it's out) and it looked pretty clear coming out the whole time, put some fresh in and a new filter along with Startron, some fuel injector/carb and run it. Get in the habit of using Stabil for Marine applications to combat the Ethanol fuel phase separation (basically octane or corn alcohol separating from the fuel). Ethanol will also absorb water more readily than the non-E10 stuff which depending on where you live, is impossible to find anymore. Another sign of putrid fuel is a strong odor of turpentine.
But again why the ugly mess in the filter to begin with? That's not a normal bad gas situation and certainly not after only 10 months. Maybe the tank had been slowly contaminated and was getting worse over time from neglect or ignoring a problem.
Let us know what you end up doing and what you find.
Jacalore
I bought the fuel line and a syphon today and have a couple containers for the old fuel ready. Mother Nature is not cooperating tho, it's storming outside... plan to tackle this tomorrow.
There is definitely water in the fuel at the filter. I don't know the condition of the fuel in the tank other than the previous owner said it was from last Summer.
I'm confused about the validity of gasoline additives, some for and some against. No consensus... ?
UncleWillie
...I'm confused about the validity of gasoline additives, some for and some against. No consensus... ?
Gasoline additives are a lot like Holy Water, You either believe it is effective or you don't.
You will never get a reasonable explanation on how either one of them actually work.
And even if you don't believe they do anything, using them will also do no harm.
Jacalore
Draining the tank as we speak (type)... siphon from fuel filter intake... the gas is clear, no water.
slag
Stabilizer doesn't do anything with fresh gas or bad gas. You have the same thing you started with and a couple oz of snake oil.
...and oil does nothing for your engine parts either, just use water. :(
Jacalore
I understand the water, if any, will be at the bottom of the tank. Still draining, should be done soon... Not taking chances, bought bottle of Sta-Bil Ethanol Treatment for fresh gas.
Jacalore
Happy Ending: Old fuel out, new fuel in (with treatment!), install new fuel filter, started right up. Adj carb idle and mix, she's purring like a kitten around 650 rpm... it's a beautiful thing. Thanks all for your help!
