MAJOR PROBLEM!! i need some good advice. i just found out that my 89 sea nymph needs to use a long shaft motor. problem is, i already have 3 short shaft motors and i'm not buying another one. what i need to know is, can i notch out the transome 4 inches then tig weld the aluminum back on to cover the wood inside? i know it can be done, but will it work w/o me and the boat getting soaked? i know i've seen aluminum boats w notches before so i assume this "rig" job would work ok? any experienced input would be appreciated. thanks.
