Re: Can I make trailer signals brighter?
Reading this again...
Your Turn signals on the Jeep are normal brightness.
Therefor, there is 12 volts to the Jeep turn signal bulbs.
The Jeep's Relay/Flasher is not the problem.
The 5 volts on the meter is a false (analog averaging) reading.
The Trailer Turn signals are dim.
Therefor, the problem lies between the Jeep Turn Bulbs and the Trailer Turn Bulbs.
That leaves us with either a wiring or a Converter problem.
If the Brake lights on the trailer are normal brightness, that eliminates all wiring between the converter and the trailer.
If BOTH turn signals are dim it is either the converter is bad or both wires from the Jeep Turn signals to the converter have the same problem.
Occam's Razor says the converter is the simplest explanation.
EDIT:
Now, having said that, I searched for schematics for just what is inside of the converters.
Baring any proprietary custom made Integrated circuits, everything I could find used multiple relays.
And looking at the schematics of the relay circuits, there does not appear to be any point that would affect BOTH turn signals.
Does any one have a schematic for a 5 to 4 wire lamp converter that does NOT use relays?
