can i pick your brains please
helokittylovr
Re: can i pick your brains please
i will undo the mods that i started with the intake manifold
colbyt
Master Chief Petty Officer
i havent tried to hook up the hose to the pump directly
There are several ways to do the conversion. At this point I am not sure which you followed. I do know that the fuel pumps with 3 barbs, in out and pulse, need a pulse line connected to the pulse barb. Connecting it to the tank won't work.
In the morning I will go back to your OP and carefully read the page to which you linked.
helokittylovr
i did both methods i started with the vac hose block then i filled the air port on 1 side after that didnt work i taped the motor and installed a pulse barb
helokittylovr
i think he meant take off the end on the fuel line and hook the fuel line directly to the in port on the pump
colbyt
What did you use to block the air port? The cut off vacuum cap or the more destructive JB weld version? When you tap and use a pulse barb, I don't think either of the ports needs to be plugged. You just you cap the old vacuum line.
Gas from the tank to the carb should be pumped up with a single line from the vented tank using a standard one way flow pump bulb. Once the carb bowl is full the pulse fuel pump should maintain the full bowl. If you are trying to use the old pressure tank I guess the air line needs to be capped.
helokittylovr
i used a metal putty, and i am useing a newer fuel tank not presureized
