Can I Pull The Cylinder Block Cover
FLOATY
I Have A 1989 115hp L6 I May Have A Broken Ring. Can I Remove The Spark Plugs And Then The Cylinder Block Cover To Inspect And Check For Cylinder Wall Scoring. Or Is There A Different Way, Short Of Taking The Entire Power Head Off. Which I'll Have To Do If I See Damage To A Piston Or Rings I Guess. Any Suggestions Bj
Laddies
Banned
Re: Can I Pull The Cylinder Block Cover
No, but you can look through the intake ports, remove covers and you can see one side of the cyl.
FLOATY
Where Are The Intake Ports & Covers As Related To The Cylinder Block Cover? Sorry For The Ignorance
Scaaty
It should be pretty well explained in the manual, which you say you have in the other post
FLOATY
If It Was Obvious To Me From The Info Provided In The Manual I Would Not Have Asked. My Effort Is Not To Waste Peoples Time On This Forum. Obviously, You Have More Time Than I Do.
