bang4dabuck
Thread starter- Joined
- May 24, 2009
- 296
I have been going through some stuff on the fuel side and for a while was looking at testing my fuel pump (but was avoiding buying that expensive OMC tool needed). Anyways on this project motor, that has been pretty much sitting around for nearly three years, it would start up on muffs. It would take a while to catch and not stall out but I just figured it needs to be fine tuned and so I started concentrating on trim and thermostat issues. So after these seemed to be under control ( a couple weeks later) I went to start her up. She would just stall out and then eventually just crank not even close to starting. I tried the gas lines at the same height and making sure ball stayed hard and after cranking and cranking and priming and back and forth on the throttle linkage I could not smell gas. That led me to believe there was a fuel pump problem.
Today I did the spray premix in the carbs deal and she pretty much started right up an then stayed running. I turned her off and cranked her again but no go. I sprayed again but no go. I squeezed the ball and watched the carbs because I noticed ball wasn't staying hard. Gas was dripping out of the carbs as I squeezed. So is this pretty much a carb issue and not fuel pump ?
