Can I run 25:1 oil mix when it calls for 50:1?
sutor623
Hey guys I have a big ol' 10 gallon tank that I use for my Merc 650 (50:1), and a 3 gallon reserve tank. The 3 gallon tank is mixed 25:1 for my kicker. If I use the reserve tank (25:1) for a motor that calls for 50:1 will it cause any misfires or idling issues?
JB
Re: Can I run 25:1 oil mix when it calls for 50:1?
Using the 24:1 will not harm your Merc. You might need to clean your plugs and decarb your engine more often, but that is all.
sutor623
Alright thanks as always JB! Just figured it was a viable question.
cr2k
Actually your carb is jetted for x amount of gas. If you run double oil your engine will run lean. It will be masked by the abundance of oil, but it will be lean.
Alumarine
Hi. Just curious what kind of a kicker takes 25:1?
I haven't seen that for a long time.
sutor623
Sure Marc. Well technically, it calls for 48:1 from the factory. It is a 1969 Johnson 4hp 2 cyl. These motors have one bearing in the crank case, so everyone with experience with them says it is better to run it at 24:1. Otherwise we have seen them run hot, or just blow up. BTW, she runs like a sewing machine......
Alumarine
Cool, good to know.
boobie
cr2k, then how come they say to run 25:1 for break in on some mtrs that after break in require 50:1 ??
fragged
No , I don't agree with that...
If you run a higher oil content you will be weakening the fuel/air ratio , this in turn will raise the cylinder temps as you will be
running a lean mixture.
Eventually if the mixture is too lean you will burn a hole in a piston or seize the engine as the cylinder temps get too hot.
It is a myth that putting more oil in a 2 stroke helps the engine through better lubrication.
Rich
jbjennings
I would run the 25:1 if emergency, but wouldn't otherwise because I'd think it would eventually coke up the piston rings----probably not but it would worry me. I wonder how much the 25:1 would affect fuel viscosity and therefore lean the mixture...... I am no expert, but would like to see some data on how much it would actually lean it out.
gonogo
I agree, will run lean. With a chain saw you would have to retune for that much oil change.
sutor623
Sorry fellas, but I'm going to have to go with the Mod on this one. Highly doubt an experienced boater and Moderator would give me bad advice. But to each his own.
boobie
Well spoken
Outsider
Going from 50:1 to 25:1 means adding an additional 2.67 oz of oil to 128 oz of fuel. Sorry, guys, adding 2% more oil isn't gonna cause a lean burn in a properly tuned outboard engine, or else any engine recommending double oil during break-in would be in harm's way ... :facepalm:
fragged
go for it dude.
i've seen many 2 stroke motorbikes sieze and burn holes in the pistons because
of a lean fuel/air ratio due to over oiling.
I am not so experienced with outboards but personally I wouldn't risk it for long periods.
Rich
sutor623
go for it dude.
Rich
Yeah well if a 45 year old engine still runs like this...... then I doubt a little extra oil is going to take her out.
