can i swap 1986 vovlo penta aq131a 275 out for a aq175a v6
nogamesjoe
hi joe her im wanting to swap out atired aq131a for an aq175a and bolt it to a v/p 275 leg and change lower leg gears what yrs 3.8 v6 blocks will bolt up to this 275 sp leg
PiratePast40
Anything is possible. It's up to you to decide how much money and effort you are willing to invest. There are several things you'll need to do:
1) there must be enough room in the engine bay for a larger engine.
2) add or modify engine mounts.
3) modify wiring harness
4) current exhaust is a single pipe. Will need to locate a "y" pipe for the exhaust.
5) transom shield will need to be of the type with relief ports for the y pipe.
6) gear ratios in the lower end of the outdrive are different so will need to replace and re-shim the lower gear set.
nogamesjoe
well thanks for the helping info there pirate I'm a welder fabricator mechanic so im sure I can pull it off but finding all the parts need will be the hard part
nogamesjoe
sorry for the delay in reply there piratepast40 Darn wind took some trees out and too the internet as well
