can I synchonize my timing using a trashcan instead of a tank on a 140 hp?
Spanish#007
I wasn't sure if it would be big enough to provide sufficient back pressure to adjust the timing and throttle, currently the idle screw is all the way screwed in and I want to adjust everything to get it running smooth again...right now with the idle screw all the way down I'm at around 550-650 rpms needle jumps alot, with muffs on I'm close to 1400, wondering if a trashcan will work for a test tank on this size motor. See this thread for more details on the issue.
http://forums.iboats.com/johnson-evinrude-outboards/adjusting-idle-1978-evinrude-140-hp-crossflow-motor-model-14083c-620522.html#post4324263
F_R
Re: can I synchonize my timing using a trashcan instead of a tank on a 140 hp?
No.
boobie
Put it in the water.
Spanish#007
Thx guys, but too late....tried it this weekend...ran great in the 95 gal trash can, ran like $h*% after putting her in the lake. One thing I have noticed is she runs worse after I've been driving her a while....maybe cuz she old? Prolly get a heat gun to check cylinder temps to make sure one is getting hotter than the others.
