Can I use a 3 wire PTT motor to replace a 2 wire PTT motor and keep the relays?
Chris1956
Honorary Supreme Mariner
Some years ago I replaced my entire PTT system on my '93 Merc V6. The original PTT system was 3 wire. The replacement PTT system was 2 wire. I swapped out the solenoids with relays and the included wiring harness to make it work.
I have a 3 wire PTT motor from some years ago, that was hardly used. My limited understanding of electronics leads me to believe that the relays will work just fine with a three wire PTT motor.
The 3 wire PTT motors have a center winding ground. So the motor uses solenoids to energize one winding for up and the other winding for down. I think the solenoid would ground the end of the unused winding on the three wire motor. That would be no harm no foul, If I have it right. Do I?
I did save the solenoids, so I could restore the original.
Another Merc PTT motor (likely ARCO) where the casing is rotted out, and the boat lives on a lift. The third motor for this Merc, since I had it in 2009. My '98 Johnny which is in the saltwater during the season is still on the orig. PTT motor. No corrosion that I can see.
Please advise.
Dukedog
think your probably tha first i've heard of that wants to go "backwards" with that type system!!! never thought of that type conversion... jus curious if it will work too........ gl.
if you understand relays, reversing contactors, etc you can make it work
both systems need 2 relays, the 2-wire uses both contactor sets, the 3-wire uses 1 cotactor set.
