Can I use a Johnson/Evinrude tank on Merc outboard?
brandhr
Tried to search to see if this question has already been answered but no luck. I have a 1967 or ‘68 six HP Mercury. I have a newer fuel tank that was used with an Evinrude. If I swap out the connector can I use the tank with my Merc? Or does the Merc outboard require a Merc connector where the fuel line connects to the tank?
just use the mercury connecter to plug into the motor.---The small one I think.
Faztbullet
If its a newer plastic EPA tank it will need a vent fuel cap to work. If its a old metal one it will work fine
jimmbo
Expect to see the Motor run smoother and more Torquey at low speed, but lose some top speed😉
Texasmark
Interesting comment, just pun or factual. If factual, what's the mechanism......I know its jest since OMC was big block torque and low RPMs vs Merc. 1 HP/cuin and 6k WOT.......and NOISY...had both over the years.....but my 2002 115 is very quiet.
