Can i use a reverse gear in my motor
dave 416
Hi i have a 1987 30 hp johnson the forward and pinnon gear are shot i was woundering if the forward and reverse gear are the same thx
wilde1j
Re: Can i use a reverse gear in my motor
Go to the BRP Evinrude website and compare the pn's.
boobie
No. Different part #'s, different design.
5150abf
Poke around on Ebay and see whayt oyu can find, frankensteining a lower rarly works and you will just be looking for a new on anyhow.
I have been down that road mixxing and matching gears to get a lower going and none of them worked, the tolerances in the lower are just to close to do in your garage and if you are off even a little it will come apart pretty quick.
You can find gears on Ebay and give it a shot but don't be suprised if it doesn't work, better to find a good used lower and just bite the bullit.
Faztbullet
If the forward and pinion are shot, the reverse is usually damaged also with some wear or dings in gear face.
