Can i use stainless steel bolts and nuts on an exhaust flange?
artificialreef
Hello again Folks, getting closer to getting this boat wet for the first time. Been sitting in my yard for 2 years and 1 month now. Heres the story so far.
Twin 470 mercruisers 1983 with Alpha R drive. Bought the boat on the cheap because sitting for 2 years somewhere else (and prob because it has 470's). Checked comp before purchase and all looks good. It has the 4 inch exchangers and the alt conv.
You will come to understand i know zip about marine (from what follows) but am learning alot from this forum. I am ok with auto. Well, I got both motors to start and run a little bit, but the port motor got hot fast (yes i had them on muffs). And smelled burning rubber and got alot of smoke from the burning rubber. I did not let it get over 180 degrees because i know these like to blow gaskets.
I pulled the port outdrive and there was nothing left of the impeller. I r&r'd it and after reading alot here think that burning rubber may have been my flappers. Though i did melt the hydraulic lines to the trim when i disconnected them to lower the stuck outdrive. Didnt tie them up and they rested on something hot.
Regardless of where the smell was coming from, when i studied the exhaust coupling to where the flappers are supposed to be i noticed one bolt missing (broken off)on the flange by the po. This boat has a berth inside and i dont want any exhaust fumes going in there and killing someone so i am going to replace the bolts and (also the donught/gasket if there is one)that will give me access to the flappers.
Long story long. I will probably have to drill that flange out and the threads will be toast. I will put a bolt with a nut on the other side. I want to do this right once.
Question? Can i use stainless steel bolts on the exhaust flange or will the dissimalar metals cause a prob. What nuts and bolts do you recommend for salt water use, and what type of antiseise should i use. I only use marine grease on all my other bolts but in a high temp situation i think the marine grease will just run out.
Thank you all for all your knowledge. I am really getting closer to this planter running well and safe.
artificialreef
Re: Can i use stainless steel bolts and nuts on an exhaust flange?
bump.....Dang this should be an easy answer for the pros here. Should i just go to midas for some bolts? I prefer stainless and dont mind the cost if thats the right way to do it.
Dont flame me for the bump. Its my first.
Ayuh,... I'm havin' a hard time figurin' out just What you're calling a Flange....
The Riser, or Elbow is bolted to the manifold...
You could use SSteel, but stock is just steel, either a stud, 'n nut, or possibly a bolt...
At the bottom of the downpipe, where it attaches to the transom, the stock bolts are SSteel, 12-point headed bolts...
edit:
2 hours on a forum, on Sunday afternoon, 'n yer Bitchin' about not gettin' an answer,..??
On an Unloved motor at That,... :rolleyes:
