oldfarmall
Thread starter- Joined
- Jun 18, 2009
- 66
Hello-
I am still in the process of diagnosing my 1964 Johnson 18hp model FD-18E. Thanks to all who have responded to my previous threads. I have rebuilt carb, soaked, blown out with compressed air, new float and adjusted, putting in new high speed orifice plug. My question is, if the new high speed orifice plug (63D) does not fix my running rich problem at high speed, could it be my low speed jet that is causing motor to run rich at high RPM? Also, fuel pump is new, so I doubt it is leaking into cylinder. Both spark plugs are wet. Spark tester verified spark jump over 1/4", so ignition is fine, new plugs and spark plug copper core wires. Also, lync & sync is good. Compression is 100 and 105. Any thoughts on the low speed jet? Thanks!
One last thing, I am running 50:1 gas oil mix.
Jesse
Jesse
