Can motor lay horizontal
yakvan
Thinking of getting a 9.9 hp outboard to transport around in my car trunk. Is it okay to lay a motor horizontal without having oil/gas leak out? Does it matter 2-stroke or 4-stroke? At what point does a 4-stroke leak oil from crankcase if you keep tilting motor over?
wayne h
Re: Can motor lay horizontal
i think you will have fuel loss from the carb bowl. every engine i ever layed down leaked fuel out.and not easy to start after that happends
Terry H
2 stroke is fine on it's side, don't know about the 4cycle motor tho with oil in crankcase...just a Thought
roscoe
From my experience, small portable 4-stroke engines will have a "safe' horizontal position. Check the owners manual BEFORE you buy it.
Outrage 19
For a two stroke lay it on the side with the tiller arm because laying it on the gearshift could brake the shift leaver. I don’t know about a four stroke but I figure the same applies.
envy83
As a rowing coach, my teams has hauled our coaching motors all over the country in that back of a pickup. We've never had any problems with the two-strokes no matter how they were situated (Johnson and Mercury 15-25hp) and as long as the 4-strokes were laid on the side indicated by the little sticker there were no ill effects(Honda and Mercury 30hp)
Kilgore Trout
Another rower on the boards!! Welcome<br /><br />Now we can gripe about boaters that don't understand a no wake zone :) <br /><br />Never had a problem with a two stroke on its side. Don't know about 4strokes.
