longstand
Thread starter- Joined
- May 2, 2009
- 293
I finally purchase a Suv..
its a
1999 Yukon Denali 4x4
V8 5.7 L
It has a Class 3 Towing HITCH.
I google this. dont know if its the correct information about my SUV:
1999 Yukon Denali SUV Performance
Auxiliary oil cooler
Auxiliary transmission cooler
5,733 cc 5.7 liters 8 V engine with 101.6 mm bore, 88.4 mm stroke, 9.4 compression ratio, overhead valve and two valves per cylinder
Unleaded fuel
Fuel economy EPA highway (l/100km): 14.7
Multi-point injection fuel system
114 liter fuel tank
Power: 190 kW , 255 HP @ 4,600 rpm; 330 ft lb , 447 Nm @ 2,800 rpm
1999 Yukon Denali SUV Handling
ABS
3.73:1 axle ratio
Rear differential lock
Two disc brakes including two ventilated discs
Immobilizer
Fullsize steel rim under body spare wheel
Wishbone front suspension with stabilizer bar independent with torsion springs , beam rear suspension rigid with leaf springs
My boat has a New Double AXLE trailer with Disk brake. which i have no clue how to use.. i don't see any wiring beside the trailer lights. I assume the disk brake on the trailer operate by pressure. when i hit my SUV brake the trailer brake activate.
Iam really scare to pull big boat. i only fell comfortable when i use my friends lifted truck to tow it. but now i have a SUV of my own i want to be sure if my SUV will be more than enough to tow my boat
My SUV has a 5.7 V8 350 Engine
the SUV it self weight about 3,000 pounds.
sorry for the English. please advice me
its a
V8 5.7 L
Unleaded fuel
114 liter fuel tank
ABS
3.73:1 axle ratio
Immobilizer
