Can someone help me identify this fitting?
synergy141
I broke the fitting off my wash pump system. This is the fitting which passes through the deck and attaches to the house on the other side. I found that they sell them in the wash pump kits but they don't have a name and I would like to buy it as a single part. Anyone know what these are called?
click the link below and the part I'm looking for is at the bottom of the pic (Black fitting with a ball valve attached to it)
http://www.amazon.ca/Johnson-Pump-Aqua-Washdown-Hose/dp/B00144BANC
Fun Times
Re: Can someone help me identify this fitting?
It's a water outlet fitting. It does have a quick connect which if looked around long enough I might find one but I'm guessing it broke off because it was either hit or due to fatigue. They make these in plastic which are around 10 bucks or one of the ones below for more. Just screw in a quick connect when you want to use it.
City Water Flange #9690-200-023
dingbat
I can't think of any reason why you would need a valve in the fitting with the hose attached. I would bag the plastic fitting in favor of a chrome over brass or SS water outlet fitting. If you look around you can find them for roughly the same price as a plastic one.
pevaguy
If you need one with a check-valve in it, go to a R.V. dealer and they should be able to come up with one used on an R.V. fresh water connection.
I believe the check valve is required to prevent back flow.
