can someone help me with these questions
always
Hey everyone I can sure use some help here. I just bought a 1987 Chris Craft with a Mercrusier I/O in it . First question is how do you choke it I looked all over and can't figure it out. The next question is I would like to service this engine before using it, where can I find info on doing that. The last question is, the trim on this Alpha drive is not working you can here it click but thats it. The guy said that the hydraulics need replacing but I do not think so. Any help with this is greatly appreciated.
stonyloam
Re: can someone help me with these questions
need to know what engine. A 4 cyl. of that vintage will have an electric choke. Which trim is not working, up, down, trailer? Need more information to be more helpful.
John_S
-Engage neutral safety switch.
-Move throttle lever forward to 3/4
-Return throttle to idle speed location
-Do that 3 times
-Move throttle to 1/2
-Turn key to start
always
sorry for the lack of info, it is a 3.0 motor and it looks like an electric choke on it. Also the trim does not work at all it just clicks any idea? Thanks
achris
More fish than mountain goat
Seized trim pump motor?
Broken wiring?
Worn pump motor brushes?
Blown fuse?
Faulty solenoid?
Bad wiring connections?
Chris..........
always
the wiring looks good, the fuse is good. how can I tell if the solenoid is bad.
Doernuth
Jump it and see if the pump works.
