Re: Can someone please help!!!
JB<br />First off, THANKS for your help!! I Have tried to determine all the info I can at this time (hope it helps) Everything works with the direction switch is in the Fwd positon. There is a greeen wire that leads toward the motor that I assume controls the forward position and there is a jumper wire that jumps over to the speed switch. When the green wire and jumper wire are reversed and the direction switch is still in the Fwd position, it will go in the other direction. When the switch is in the Rev position nothing happens no matter how the wires are. <br />When the speed switch is used it does vary the speed of the propellor so I know it is working as it should be. <br /> <br />The direction switch consists of the following:<br />1. The pos & neg leads from the batt<br />2. A med size green wire (leading to motor)<br />3. A med size white jumper wire to the speed switch.<br /><br />The speed selector switch consists of the following:<br />1. The med size white wire leading to the direction switch.<br />2. A med size red wire leading to motor<br />3. A small blue wire leading to motor<br />4. A small yellow wire leading to motor.<br /><br />I hope this will give you some idea of what we are looking at. I have a volt meter, and can use it but not knowing how the motor works and why, that doesnt help much. If all else fails, I have access to a digital camera when I return to work on Monday and can take a pic and send to you if needed.<br /><br />Thanks a million<br />Lostinthewater
