jaredbuybadboat
Thread starter- Joined
- Aug 12, 2007
- 3
Bought an 89 conquest with an OMC 2.3L 4 cyl. Third time out it abruptly started making a knocking sound. I had a marine mechanic check it out and he said when he pulled the wires for the 3d and 4th cylinders (one at a time), the power didn't quit much. He said I might look for a pinched wire. Then I had my roommate's dad (good car mechanic) meet me in the water to listen to the sound and he said he thought it was a rod knocking. We pulled the motor and the oil pan and couldn't find anything wrong, i.e. no metal particles, nothing loose, no considerable scoring on cylinder walls, etc. He said it's possible that the problem isn't visible due to the tight tolerances of the engine.
When we were pulling the motor, I did see that one of the wires had a small gouge in it down to some white material. He said that wouldn't cause the problem but I wanted to get a second opinion. Any advice? At this point I could replace the wires and put the engine back in, but don't want to screw with it if it is not the problem.
