Re: can`t get gas to fuel bowl.
The bulb's not getting firm, is it?
Only just a few possibilities:
Hold the bulb vertical, with the arrow pointing up - gravity helps close off the intake valve in the pump.
If that doesn't work, either the bulb is faulty or else the line's sucking air upstream of the bulb.
Make sure the quick-disconnect is all the way on.
Then check all the hose connections.
And the pickup tube inside the tank.
Could be a hole in the pickup tube.
Or the either the male or female quick-disconnect fittings are faulty.
Narrow your search by taking the quick-disconnect off the hose and sticking it (the hose) down into the fuel filler opening, and squeezing the bulb.
[note to lorin - if I had to go through that procedure to prime my fuel line, I'd do some troubleshooting]
