Can this pull my boat???
penguin
Re: Can this pull my boat???
hey rhino' I have the airlift setup also, and it does work great. I have a 2001 olds bravada w/ 4.3 v6 and 373 gears, and the airlift was needed to go from my 16' to a 24' chaparral villain III. The lift was about 4 inches.
Mercathode
Brad<br />If it does not have already put you a tranny cooler. Those A4LD will be fine if kept cool.
jmeydenbauer
Brad,<br /><br />I've got a '77 Thunderbird Formula 20' on a tandem trailer that I sometimes pull with my wife's Mitsubishi Montero Sport. As long as you have trailer brakes and use a frame mounted hitch, you will be fine. I did need to add the air helper springs to the MS though, the rear suspension is so soft on those damn things.
