Can VRO give me better gas mileage?
Tripp Halbert
1996 70hp johnson w/ vro. I bypassed the vro when i first bought the motor but i am curious; does anyone know in fact for sure that VRO/oil injection could allow the motor to get better gas mileage vs the pre-mix method???
Re: Can VRO give me better gas mileage?
It is doubtful that the VRO would provide better fuel mileage. The motor you are discussing mixes oil and gasoline at about a 60::1 mix, so premixing would use a bit more oil.
Tripp Halbert
That makes sense but is more of a question on gas mileage considering different oil/gas ratios. i guess what i am really curious about is did OMC maybe design the VRO system to function as more than just a luxury of not having to premix? Does it have some type of performance or gas mileage advantages? Just food for thought!
JoLin
No, Tripp, it doesn't have any performance or gas mileage advantages. I owned a VRO, and by my estimation over a couple of seasons, it used a bit less oil than it would have if I'd mixed it myself at 50:1. Like Chris said, VRO more precisely adjusts the fuel:eek:il ratio based on engine RPM. Aside from convenience, that's all it provides.
Tripp Halbert
Okay well good then I'm not missing out on anything ! :) I appreciate the input you guys
boobie
The oms was an up graded vro and mixed oil and fuel at a constant 50;1 ratio.
Tripp Halbert
yes i am reading that OMS is basically VRO2. Same system just upgraded internal parts to withstand a higher wear and tear. I guess they stopped writing VRO (or VRO2/OMS) on the coulings as well due to all the hype about the earlier models system failing?
