Can you overinflate?
mikeya4
Hi, I have a 9' inflatable which came with bellow style foot pump, it has no pressure gauge so i don't know when it gets up to pressure, can you over inflate with these foot pumps or should i just inflate until it becomes to difficult, the pump I have has no place for a gauge and I cant seem to find anything over here that fits my valve, any ideas?
tashasdaddy
Re: Can you overinflate?
they usually come with marks on the rubber hull, and a measuring instrument. you check the too items until they match. that is when it is inflated properly. air pressure cause the tube to stretch. then in the heat of the day, the pressure goes up, and at night it goes down. all it is a fancy balloon. too much pressure and POP.
bayman
One thing to watch with inflatables is the temperature. If you inflate it on a cool morning and then it's sitting on a scorching hot beach at noon things can change and you may need to let a little air out....especially if you have a dark colored inflatable.
TOHATSU GURU
Depending on the pump...You probably will have a hard time reaching full pressure anyway. If you have a 2-stage pump with a low pressure side just use that side.
MrBill
Yes....when it goes KaBooooooooooom...you have over inflated. Sorry, I couldn't resist
I agree with "DJC". With a foot pump I haven't managed to get up to 3 lbs in the tubes. I run my Zebec at 6 lbs (cold) and have never had a problem. Check with the manufacture to see what pressure the tubes are tested and go from there.
ng
sunaj
I just bought a zoom Zodiac from Iboats, kinda suprised they don't sell a pressure device that will fit in the hole, seeing how overinflating will void the warranty
deejaycee_2000
I made my own pressure device from an pvc garden fitting .... works perfectly ...
Nos4r2
Ribshop in the uk (google them) sell a pressure gauge that fits.
