Can you use hydralic hose in a boat bilage?
j_k_bisson
Can one use regular Parker hydralic hose in plumbing the bilage and drains in a boat? Or is there some spec these hoses need to meet? I'm not talking the fuel line or vents. Just everything else. I have not fresh water supply on the boat so no isues there with food grade standards.
Is it a matter of cast that theboat builders don't?
Jeff
Robbabob
Re: Can you use hydralic hose in a boat bilage?
Don't know why you couldn't use a hydraulic line.
robert graham
Hydraulic hose would work but might be overkill/expensive for a drain, maybe check Home Depot for a variety of clear plastic hoses that would be very water, oil and fuel resistant and you can see what's flowing through them! Good Luck!
j_k_bisson
I can probaly get hydralic hose free from work. That is why I was asking. I could always buy something else, but free always sounds soo much better!
Jeff
ajgraz
I'd say as long as it's OK for automotive coolant and is gas/oil resistant (some of that always gets into the bilge), should be OK. Got a link to the specs?
I'm using 3/4" ID coolant hose from the auto parts store.
j_k_bisson
I believe it is 301 or 201 parker hose.
sasto
If you can get your hands on Parker hose and fittings....at no cost... for your application?....if she were mine.......by all means do so.:)
Yacht Dr.
I would only be worried about using Steel braided lines on plastic fittings.
I would assume you have to double clamp it down tight..will it Break the plastic barbs on those fittings ?
j_k_bisson
I actually took the advise of
October 20th, 2010 01:48 PM
And bought the clear nylon reinforced tubing from a cheap suppier. I iked the idea of seeing if it was working. And seeing I am very anal about the workings of my boat I will keep a close eye on them for cracking and stuff. So Now need to order fittings for the ones I broke.
