Hi again guys. Some of you may recognize me from a post on the Mercury motor section. I first posted in that section thinking I have a Merc motor when it is indeed an Evinrude. I am having a little problem with it stalling out when trolling (very slow idle only) where I have to pull the choke out slightly closing it about 25% or even less to keep it running. I got the advice to clean the carb which I will do, but now I have a second question and posted it correctly in this section.
My motor is a 1991 (not '86 like I last reported) Evinrude, model # E6REIA. (Found all of this out when I got my manual out from the garage today). In the service manual that I have, it shows a fuel pump filter and how to clean it, which I did last fall. It also shows a fuel line filter and how to clean it. I cannot find this fuel line filter on my motor. When I bought the motor just last year, I bought it from a fiend that I worked with for 30 years and we retired together in 1999. He told me last year when I bought it, the motor had only about 10 hrs. on it, which I truly believe. It now has about 50 hours on it since I used it to troll with last year. Ran perfect except the last couple of hours, wanting to stall out while trolling unless I slightly close the choke like I sated above. I know that my friend did not remove the existing gas line filter, and nobody else did. Maybe it never had one even though it shows in the service manual??
Can I add an inline gas filter outside the motor on the gas line going into the motor with no ill effects on the motor? Does anyone know if any of these motors were built not containing a gas line filter that is indicated in the manual? Thanks for any ideas you may have on this.
