q7myfirstboat
Thread starter- Joined
- May 31, 2016
- 64
Bought my first boat last year; 01 Tahoe Q7 With 5.0 Motor. Winterized properly and it ran fairly well, but never got about 35mph area. (I will save max speed for another day.) Just took it out and it will not go past 10 MPH. (Winterize procedure I did.....changed oil, drained block, filled with antifreeze, replaced water separator and filled with seafoam. Filled tank with stabilizer and ethanol free gas and fogged it a few minutes, then overloaded to stall it.)
After a lot of google... hub/prop/bearing? Neutral, it revs fine and motor sounds great. In gear, 10MPH max and 1900 RPMS... From 30% to WOT, nothing changes.
In reverse, it appears to work better, but almost sounds like a slipping clutch when I go faster...
In gear with motor off, I can spin prop easily and it clicks, but will not spin in reverse. In reverse, I can spin backwards with clicks, but not forward.
I have already removed carb and plan to rebuild it as well since some gas was on the manifold after sitting through the winter. I am going to replace water separator, plate and filter as well. (Hopefully this will contribute to my sluggish WOT.)
Last year, I put on a 4 blade 19 pitch and replaced the bearings with it, but what exactly would I replace now? (The whole kit you can purchase from Iboats.)
Also, when going in to gear, it clicks or tries to grab, so I have to push lever forward fairly far, then pull back to go slow? Does that make sense?
