Re: Cannot properly adjust linkage to maintain F & R
Howdy,
I'll assume you're talking about a King Cobra Stern Drive...
If you do not have a correct OEM OMC service manual you should not even attempt it.
I would be willing to bet that your lower shift cable is either corroded from sitting all those years or was not adjusted correctly from before. In either case you should not try to run it at all until the cable gets inspected/adjusted and replaced if needed.
If you do a search of this site you'll find a LOT of info on lower shift cables and the like. You probably need to find someone who works on Cobras to fix it for you. Based on your year model and engine you may have a Dog-Clutch model.
Go
here for info on it. It will get you up to speed a little on what you're up against.
Also you can go
here for a lot of service info.
Good luck,
Rick
