Captn Dave
- Joined
- Dec 5, 2001
- 176
Re: Canoe in two Project launched (pics)
Wimperdink,<br /><br />For whatever reason, Great project.
I have to figure that when just floating with a full load of motor, gas, and me that these will be drafting 2 to 3 inches of water... they are only 4¼" deep. I'm thinking when they fill up with water cause of the lack of tops, that they will no longer do their job. then my stuff is wet tooOriginally posted by One More Cast:<br /> I wouldn't even put tops on them so you could use them for storage.
Curiosity, how do you do a good even carve on the hard foam? Kitchen knife? Sharp spoon?Originally posted by Bondo:<br /> Being a fiberglass hull,........<br /><br />You can Easily carve a set of sponsons to fit the back 2/3rds of the hull,+ Glue them on with Epoxy,..........<br />Maybe incorporate some Hull Lift with them,......<br /><br />Epoxy,.. Unlike Polyester resins are Usually more Foam Friendly,......<br /><br />Ayuh,.....<br /><br />Throw on a couple layers of Glass,+ Take a Hammer to the blades on that 4hp Prop,.......... <br />It's going to Need More Pitch,......................
<br /><br />I can See it Now,...........
