Re: Can't access ebay, what happend?
Ryan .T.........<br /><br />From the upper left hand screen, scroll down to "find".....<br /><br />In the "box", enter..."browser cache" and send. The brower cache will show up.....drag the browser cache off the "find" screen and on to your main screen.<br /> <br />Repete the same process with, "history.html" and "favorites.html" and "cookies.html".<br /><br />Clear the find screen and drag the above icons to the recycle bin or delete icon, that should be on your home screen.<br /><br />In the upper right of your screen, there should be a display of how much memory you have on your hard disk.<br />You should see an increase in "memory" numbers once you complete the deletion of the above files.<br /><br />This does not actually delete the files, only the contents of each file, thus increasing useable space.<br /><br />Have you checked the "Parental settings"? If someone else uses your computer, they could have blocked you out of some types of programs.<br />Try cleaning the file's first and do it frequently after you use your 'puter. Delelting these files can also increase your 'puter speed, at least it works on my wife's "antique" Mac. <br /><br /><br />...Bob in Calif...
