Can't Access Thermostat - Mariner 1982
Grant123
I have a 60Hp Mariner 1982 Model 675 2 Cyl outboard. How do I get access to remove the thermostat? My manual tells me how to test the thermostat but not how to remove it. There is a cover plate on the side of the motor but I cannot remove the bolts at the bottom because there is not enough room before they hit the side wall of the cover housing. Thanks for your help.
Grant
Laddies
Banned
Re: Can't Access Thermostat - Mariner 1982
On model 675-2 cyl 60HP engines the thermostat should be on the head
Grant123
Thanks Laddies, yes the thermostat is on the side of the power head. It is covered by a triangular looking plate which is bolted to the head with about 10 bolts. If I try and remove the row of 3 bolts at the bottom of the triangular plate, as they are undone, they hit on the metal side of the outboard (the base that the cover goes on). So, I cannot remove the triangular plate and I cannot get access to the thermostat. The reason I want to check it is that I only have a dribble of cooling water exiting the head. I also need to check the impellor.
Regarding the thermostat ? I don?t have the remove the power head do I??
Grant
Grant123
Thanks Laddies, yes this is my motor and I now see where the thermostat is located. I have been looking in the wrong place. Thanks heaps!
