Can't believe what was in the exhaust port!
Dhadley
Re: Can't believe what was in the exhaust port!
The 235 style motors have the "tuned" exhaust and inside the back of the block in the exhaust area are "stuffers". The theory is that they act like headers to tune the exhaust. If the motor is being lugged it's possible to melt off a piece due to high combustion temps. It's most likely a piece of one of the stuffers.
bucket235
looks to me like a piece of an anode but i dont think they used them in 81, i am assuming its an 81 if the last 2 digits of your model number are IB instead of 18. I have also seen chunks of exhaust housings broken off and rolling around in the lower.
the motor is an 81. what is an anode? are the filler blocks and stuffers the same thing?
it sounds like i should just keep running it!
chadpcb
You say the inside the lower unit is chewed up by the prop area.
It is possible that a piece of the lower unit broke off then the friction from that piece causing it to build bigger and bigger. Aluminum has a low heat temp which is at about 635 degrees and you can only imagne a piece getting stuck in the edge of the prop rubbing at 4000 rpms the heat that would cause melting layer upon layer on the smaller piece of aluminum making grow into what you found.
just my .02
Dhadley
What's the top rpm with an average load?
jay_merrill
This seems like the most logical possibility. The piece in the photo looks like it is a chunk of melted alumnum block, to me. As for the shiny appearance, that is exactly what I would expect of a piece of aluminum that has been burnished in any way, such as being rubbed against the inside of the exhaust hub of a gearcase, to look like. In fact, you can polish a piece of aluminum sheet to look like chrome. A good example of this, is the polished intakes on a Blue Angels jet.
..... reminds me of an incident we had back in the 90's, a GE CT7-9 engine with less than 200 hours on a Saab 340B failed catastrophically just after take-off. The lab found an alloy foreign to the engine, but commonly used in the manufacture of tools.......
I had to smile at this one, because most people will think you are talking about a car, rather than a twin engine, turboprop aircraft. BTW, that "tool material" that was found, was most likely what was left of an impact driver tip. They are made of hardened steel and having someone leave one in the intake of an engine, is not uncommon. I once watched an Allison T-56 on a C130 Hercules tear itself up, after ingesting one on engine startup. Once it started shredding compressor blades, the engine became so unbalanced that the motor literally looked like it was going to come off of the airplane. In fact, the prop spinner did come off!
boobie
Skeetr, If you read my post again I said only on the V-4 "Bubble Backs", not V-6.
