Hello,
Just replaced the rotors/calipers/ and coupler on my trailer (Kodiak and Titan 60). I reused my reverse solenoid from the previous install.
When trying to get fluid in the system the coupler will give a couple pumps then just stop, not able to compress anymore. Am also not getting anything from the calipers. I have tried using gravity to feed the fluid down the lines, and tried a vacuum pump. But get nothing!
To sum up, coupler feels locked and unable to pump anymore. Bleeder valve open on caliper and no fluid.
Should the fluid flow from the coupler if I disconnect the hose or is it only actuated down the line?
Thanks
mike
Thanks
mike
