Can't Find 50 AMP Breaker
kbjorklund
Anyone know where the 50 AMP breaker is on the 5.0GXi? Owners manual says its on the engine but I've been all over that thing and I can't find it anywhere. Just thought I'd ask before calling the shop again.
SpinnerBait_Nut
Re: Can't Find 50 AMP Breaker
Mercruiser/Volvo/OMC I/O and Inboard repair forum
Don S
What is the FULL model number is your 5.0GXi?
There are some letters following the GXi, need to know what they are.
kbjorklund
I'll take a look tonight Don. Thanks for the response!
Don S
The only 50A breaker that I know if is for the trim pump, and it's in the Fuse and Relay box on top of the engine.
Your owners manual should show you where it's located. Look on page 50.
kbjorklund
I've been through that box a couple times. I've seen the 20A and 40A fuses along with a 40 amp buss and the relays of corse. Nothing in the 50 range. I'll check again. You're right though regarding the manual. Trim fuses are labeled as being in that box.
Don S
