Can't find info
lynnboy021
When I order parts from my marine dealer they always ask me for the serial numbers but I can't never find any numbers.... I think I have a 88 Chevy omc 5.7 cuz I have the log exhausts but they always wants to make sure... I have no info on valve covers or top of the air filter.... so question is is there any more numbers I can look for that will tell me my motor info???
bruceb58
Re: Can't find info
Do you have an 88 Cobra? You dn't need the serial number, you need the model number
These are 1988 5.7L model numbers:
Model 574AMLGDP
Model 574APRGDP
Model 574BMLGDP
Model 574BPRGDP
lynnboy021
Re: Can't find info
Yes I have a cobra.... yes my dealer gave me them numbers but can't find it on my boat so should I just pick one??
lynnboy021
Re: Can't find info
Model 574AMLGDP
Model 574APRGDP
Model 574BMLGDP
Model 574BPRGDP
I see them numbers all have 574 but my motor does not have a 4 barrel????
lynnboy021
Re: Can't find info
so looks like my motor model number should be 572bprgde
Howard Sterndrive
Re: Can't find info
only the 305 came with a 2 BBL, all 88 350s had 4 barrel carbs.
You can also look for a casting number on the block - the googles would probably lead you to a sbc chevy casting number guide somewhere
lynnboy021
Re: Can't find info
Well I was looking at pics of 305 and 350 and my motor setup points to 350.... I will look at Google and see where I can get the casting numbers
lynnboy021
Re: Can't find info
So the casting numbers I found is 14010201 and Google says it's a 1980 to 1985 and it's a 305 Cid.... so can I just make up a model number???
Howard Sterndrive
Re: Can't find info
502APRGDP will be your model number if the boat is a 1988
OMC tended to use GM parts that lagged the automotive line by a few years.
