Can't find OMC Gear Lube
LWW
We used to use OMC HPF gear case lube in our OMC Cobra sterndrive but can't find it anywhere around here now. The closest thing is Quicksilver High Performance lube. Is this a suitable substitute or is it not compatible?
HT32BSX115
Re: Can't find OMC Gear Lube
Just use the Quicksilver HP lube. Be sure to follow the OEM manual directions in refilling the Cobra.
Cheers,
Rick
WillyBWright
A lot of places use the green Merc stuff in all drives. I've never had a customer with a problem as a result. Make sure you get it all the way into the upper drive.
bruceb58
You can use Mobil 1 75w/90 GL5 synthetic gear lube available at your auto parts store.
