cant get enough rpms
GKT
i have a 1980 black max 200 on a 20ft center console and its only getting 5000rpm and around 33 mph. i had a 19pitch prop on there before and it was around 4500rpm and 27mph. I switched it out for a 17pitch, reajusted the timing(it was off)...checked the float levels on all carbs. and im still just getting 5000rpm. the book says wot rpm is 5300-5800. i suppose i need to go down to a 15pitch? this seems a little too low of a pitch though. wont i lose mph? any help?
GKT
Re: cant get enough rpms
compression checks out good. all around 120
Faztbullet
Easy fix.... your motor has the wrong gear ratio. Someone has installed a 2:1 ratio off a 2.0 liter engine , you need the 1:87 ratio for the 2.4 liter. You can check this with a prop calculator. If you had the 1:87 with 17p prop @5000rpm your speed would be 38 mph,5500 rpm will get ya 42 mph.
Faztbullet
You can also turn the flywheel by hand while in gear, cout how many times flywheel turn to make 1 turn of prop...
GKT
dang. thanks man. you're good. do i just need to get a new set of gears and install them or a whole lower unit?
GKT
oh. i just looked in my service manual and it says the gear ration for the 200hp serial number 6201969 and below is 2:1..my serial number is like 53 something. the 175hp and other 200hp motors are 1.87:1 though. or will it even matter if i convert mine to 1.87?
GKT
never mind...i see the 2:1 is for a 20 inch shaft. 1.87 is for 25inch. mine is 20 inch with a 5 inch spacer...ohhhhhh
Faztbullet
You are correct, I looked in my manual(90-97658) and it shows the 2:1 ratio for that year(80-81). Go back to the basic's and check spark as you may have a switchbox bad and running on 5 cylinders and check ratio by hand as previously posted...
CharlieB
Rig some LONG jumper wires and DVA test stator at Problem speed. And you will have to do it twice, to verify that BOTH ignition boxes are getting the same voltage/current from the stator.
If voltage is not to spec it will limit RPM and power.
GKT
i do know that the starboard bank of cylinders is hotter to the touch than the port side. but i have both thermostats in. im out of ideas. i dont see how changing the gear ratio would increase the rpms. if anything, i would think it would lower them.
Have you done a cylinder drop test. Find fuse pullers at Home Depot/Lowes increase speed to no more than 1000 rpms on flushette and pull the spark plug off the plug and listen for rpm change. Sounds like you have a dead cylinder. Possible plug or switchbox etc.
GKT
i did notice that number 3 cylinder is carbonized. (i pulled the heads) the entire head is black with carbon. but that means its getting spark. so i checked the carburetor for that cylinder and all that stuff is fine too. ive got all new coils
GKT
the spark plug for #3 cylinder is black and carbonized too. all the spark plugs are old. i dont know how old since i just got the motor in august.
GKT
and i do notice that after every trip i have fuel dripping from a/the carburetor(s) somewhere (looks like out the front).
