Intoodeeep
Thread starter- Joined
- Aug 13, 2011
- 64
Ok, I have a 1988 Johnson 175 that I have put a lot of time in after building a new engine. The linkage setup was finicky with the last one and I may not have had it completely setup right the first time. But I have pulled the lower unit and have measures the shift rod to spec and setup the linkage with it in neutral and per the manual.
The issue is I can get it to go onto forward gear fine but it will not go into reverse. or I can get it to go vice versa if I adjust it or even to get it to go in between. But can't get the sweet spot. I have even adjusted the rod up and down a turn or two in both directions with the same result. It is back to its correct measurement now. I have found that when I shift the control box into reverse to the first detent it will not engage. But if I move it past the first detent it will engage. I disconnected the control cable and found that in neutral the cable has zero play. But if I shift it to the first detent in reverse, the cable has an additional half inch of travel that the cable could travel. If I move the control box past the first detent the cable has a quarter of an inch the cable could travel. The cables are only a couple years old and are from Teleflex. Does anyone have any idea what is going on? Is it the control box or the lower unit that is the problem or is it even the cables. I have not taken the control box apart yet but it moves freely and is not binding. The gear shift will go into reverse and forward with no problem with shifting the linkage at the engine. Thanks in advance.
