MaddysDaddy
- Joined
- May 10, 2010
- 149
i have a small sporttwin i removed the lower end. i slide it back in and reconect the rod but when i try to slide it in that last 1/2 '' it wont go in. i dont want to force it. what do i do ???
i have a feeling it has some thing to do with the copper (water intake?) pipe that slides in along side the shaft. i can line it up with the hole no problem then slide it in. is there another hole that it must past thru? Also the copper is bent. Should it be straight?
