cant get lower end off 85hp
rick74631
1976 85hp johnson i got the shift rod unhook got the 4 bottom bolts out and the long one and got the flywheel of and it has not drop very far you can see a little in there any help would be good thanks rick battles my email is battles_ricky@yahoo.com all check on here to
iwombat
Re: cant get lower end off 85hp
Don't forget the secret one under the trim tab.
kenmyfam
Yep, look for the non obvious one.
rick74631
got the one out under the trim got 5 bolts out and unhook the shift rod and took the flywheel nut of is there more than that thanks rick
iwombat
There are 6 bolts plus the shift connector that holds the lower unit in place (not including the bolt that holds on the trim tab). Flywheel has nothing to do with it.
rick74631
ok got one still in there then got the ones one the side's an the one under trim the long one thats five have to find the other one is it covered up
iwombat
Four along the sides, one to the rear of the four (the long one) and one UNDER the trim tab. i.e. take the tab off and there's still one under it.
Edit: Ok, I guess to be precise it's actually COVERED by the trim tab (and really above it if the motor is on the boat still). Anyway, you gotta remove the trim tab to get to it.
rick74631
ok i got it now thanks alot all try it again later an let you no thanks again
