Can't get starboard engine to run after a bunch of work.
ttownthomas
Well...I replaced the white resistance wire with a NOS quicksilver resistance wire. Prior to install I tested the resistance of the new wire and it was about 2ohms. I unwrapped the harness back to the lug connecting it to the white key on wire and wired it up. Still getting 5ish volts at the coil. Pretty much the same reading as before. Then it started raining and I packed it in for the night.
When the points are open I get 8v on the better running motor and only 5 on this one
This tells me there is a coil issue, or something that is connected to the + side of the coil has an issue. Your motor should have a white wire (you just replaced) and a Tan wire going to the starter.
If the NOS wire is disconnected from the coil, and the key is turned to ON, do you read 12V?
If 12V is present, reconnect wire to + side and then remove all wires on - side of coil. Turn key ON and do you have 12V?
If you have 12V, then was the condenser replaced?
ttownthomas
Is the condenser the same as the coil? I know the coil "condenses" the voltage....So I assume yes
EDIT. Google answered this for me.
achris
More fish than mountain goat
No, condenser is the old name for the capacitor. The round silvery thing that is inside the distributor cap next to the points.
Chris.....
ttownthomas
Yes
Yes
I don't know. But this coil and distributor and cap all appear to be older than the good running engine.
Here are photos of what I have
Why don't you think its the coil?
With the wires disconnected from the Negative side of the coil, you get a full 12V. If the coil was shorting out, or causing a larger drain, the voltage would be lower.
You could try one more thing to verify
Connect all wires back up. Remove distributor cap and make sure points are open.
Loosen connection where the 2 wires connect to the points, and remove wire to condenser, retighten distributor wire on points
Turn key ON and there should be 12V
If there was 12V, touch condenser wire to original connection. Voltage should still be 12V. The condenser does not draw power thru the coil
Here is how the points system works
achris
There's more coils replaced in a day than fail in a year!
In more than 40 years working on all manner of cars and boats, I've seen 2 dead coils.
Chris.......
Scott06
while coils do fail more often than not it is something else. If you google it or look in merc manual I’m sure you can find ohm ranges for primary and secondary windings to vet coil. The few times I have had bad coils(one VW, one 1975 Envinrude15) they ohm Ed out bad easy to rule out. Alternatively swap coil from good engine to bad, if problem goes away it’s the coil.
tank1949
Perhaps you have tried this, or not? If you have one good running motor, swap good parts with motor that doesn't work, especially coils and notice what happens. Write down what you have done! TRUST ME! Return good part back to good running motor.
Willit float
I went through something similar on mine. The coil was failing, it would start run fine, then start miss stall etc. I’ve seen about 6 failed coils over the decades. This could be various things, getting good info here. Mark the wires on pos and neg both coils. Swap coils and test run with water hooked up to outdrive.
On mine after replacing coil, points, condenser, rotor, cap etc. I thoroughly rebuilt my carb at the same time. It then ran fine.
Your manual shows and others have stated desired voltage to coil both with start and run positions.
You stripped back the resistor wire and re ran and sounds like that did not make any changes.
****Swapping coils make sure they have the same number and indicate if internal or external resistor. Simply performing an ohm test on the coil would show a constant fail but not intermittent. Coils are cheap, I upgraded the distributor to electronic breakerless points.
Also, check your distributor run out, with the power off at the main source, pull the cap. Remove the rotor and test top shaft side to side wiggle. Mine was shot, it had excessive horizontal play which caused impossible point accuracy.
ttownthomas
I replaced the cap, rotor, points and condenser. Set the points gap to .016 and the motor runs much better but still rich. When I set my points gap this is how Im doing it. Is this right:
File points
bump starter until the points lever is riding right on top of a cam lobe
put the .016 shim in-between the points
screw down screw to hold points in place
First time I got dwell (measured with dwell setting on multimeter) of around 40 then did it again and got around 27. Spec per fsm is 31 to 34 degrees. Is there a fine adjustment method I'm missing?
After you tighten the points down, the feeler gauge is reinserted to check its set correctly. The spring tension on the points it self will close the points.
Increase gap decrease dwell, decrease gap increase dwell
ttownthomas
I am doing it correctly then....its just fiddly i guess. Any tricks to getting the points to rest right on top of the cam lobe? I'm Already using a starter button.
Easiest way I found, is loosen dizzy bolt, adjust turn to set points, then turn dizzy back. Start and reset timing
Willit float
Duh. Of course. This makes perfect sense. Thank you
Yes, I put a piece of tape to identify the position alignment or mark a black line for the distributor, loosen it and turn it to get a smooth accurate lobe. Now I said earlier that my bushing was worn causing the gap to be impossible to get accurate because of the wiggle. So I got a new electronic distributor and it is great.
