glassmaster68
- Joined
- Feb 17, 2010
- 227
66 evin lark8,,,was going to replace coils and points,,,,used a puller and stretched the bolts,,,went and got some grade 8 and broke one,,even tapped on the shaft a little,,not too hard,,,,using impact to run down the puller,cant get this thing to budge,put a big bar on the puller, and a flywheel wrench on it with cheater bars ,,then broke of the grade 8 s,,got it out luckily,,,,,,,shaft and flywheel are not rusty and everything is really clean,this motor was hardly used,,,any ideas how i can get this thing off,,,already have new coils and points to go in,just cant get the dang flywheel to slip a little,,,,,,,also,with my point set,there is a small capsule with some lube or something in it,,what should i use this for?
