toplsvette
Thread starter- Joined
- Jul 31, 2008
- 9
Hello,
I just changed my engine (4.3l gen+ alpha1 lower unit) and cant seem to get water up from the lower unit to cool the motor. I put a water hose on the hose that feeds up from the lower unit to see if it blocked and it is not. Water came out the lower unit. I filled the block up through the water pump hose to see if that helped and to no avail. I removed the thermostat to see if it might be a defective and still no water.. Should the water come up from the lower unit and run out the prop without the engine running? Any help will be greatly appreceiated..
Eddie
Eddie
