I replaced the prime bulb and changed the water separator. I put 5 gals in the tank even though the gauge reads 1/4 tank. I cannot get the prime bulb to fill. When I took off the separator it was full. Cannot even get that to fill. When I cut out the old bulb the tank side of the hose had fuel in it. Can a clogged line on the motor side of the prime bulb block the priming? Could this be from the fuel pump. Last time I tried to go out the motor started and ran a couple of minutes then i lost the prime and haven't gotten it back since. This is an '89 225.
