nytevizion
Thread starter- Joined
- May 13, 2009
- 15
After replacing the seals, bellows, lower shift cable and reinstalling the drive, the drive wont shift into forward or reverse. Cable wont move on the engine side but moves freely with drive off.
The cable ball is in the jaws, they were closed. Drive is in neutral as the prop spins freely both ways. Control shifter is neutral, as the boat won't start without that. Attempted to shift while engine is running. The shift mechanism in the stern drive seems to move freely when drive is separated from bell housing. When the drive is separated, the jaws and entire mechanism seem to pull out without much effort releasing the ball as it should.
One attempt, I installed with the drive in reverse gear. I was able to manually push the cable and shift the drive into neutral while engine running. It shifted fairly easy but then was unable to shift out of neutral either direction.
It shifted without issue before attempting this bellows repair. I only changed the cable because it was wearing through the plastic casing near the transom.
I am debating taking the front cover off to inspect the ball detent but like I said, this wasn't an issue before this repair.
What am I doing wrong?
