sambluckie
Thread starter- Joined
- Jun 27, 2012
- 24
Just finished replacing drive bellows. Was relatively easy. Everything all ready for the easy part. For some reason I can only get the outdrive to where the 6 studs are at the outdrive holes. Made sure the shifting "shoe" on the outdrive(pointing forward) and the shift lever on the housing are lined up. Thinking the splines are not lined up. Tried turning prop shaft CCW. Can't seem to get it to move. Turn it CW and the shoe moves out of alignment and the prop shaft then spins freely in either direction. I must be doing something wrong.
