Cap Removal Problems
JC612000
Having difficulty getting the cap off my fish and ski. Appears like it is sealed (bondo?) at the splash well with a support structure attached to the transom on the inside. Anyone run into this? I've got to get the cap off, but this thing is a monster and will not budge at the transom.
JC612000
No Title
Watermann
Thinking I would get out a saw and start cutting, the cuts would be easier to repair than splits and tears.
nurseman
+1 on cutting it free and repairing the cut. Much easier to repair a clean edge vs. a splintered and torn edge. Don't let the thought of cutting it apart spook you, the glass really is easy to repair.
djm3801
+2. I have seen folks use a cutting wheel, going in from the top and inside of skin. I cut side caps off my McKee - transom wood was rotten and since I knew thickness of glass was about 1/4" I just cut in from back a little over that with a coarse blade jig saw.
Woodonglass
Use a multitool saws all jig saw what ever it takes to cut it free. It can all be repaired quite easily!!
JC612000
Thanks for the replies. I was able to work on the boat today between Honey-do's. I decided to attack from the inside. There was nowhere good to cut it near the splash well on the outside. There was a 2x4 glassed to the transom on the inside. I was able to cut it out, and then had enough room to get a small dremel tool on the inside skin to cut around the splash well. The back is now free! It wasn't easy, but I guess that's the way it goes.
JC612000
Hi folks, looks like I'm about ready to buy fiberglass/ epoxy supplies to start the rebuild process. I'm near a West Marine store for the next couple days. Does anyone have an opinion on their products? Figure it might be a good opportunity to save on shipping and any hazard taxes.
Woodonglass
Sooo are you using Epoxy?? West Marine epoxy is really good stuff and Priceeeeee!!!!:eek: Polyester Resin will work really well and IF you can buy it locally and save shipping, it's about 1/2 the cost. Shipping epoxy is not to bad since it's NOT classified as a hazardous material like Poly is.;)
JC612000
Thanks, was thinking about epoxy, as I understood it to be a bit more forgiving for newbies. Going to price out what I thnk I need at west marine, they have a lot of good info on their products that I've been reading about today.
