capping the stringer
brian3127
how many layers of 8 oz. cloth should i put on the stringer for the cap and cross members.
oops!
Re: capping the stringer
capping it is gonna be tough, you want 2 layers, of 8 oz,
do your best to have the new glass contact the cured glass on the stringer vertical.
weve gotta come up with a better system.....next time i do theis im gonna reccomend half round or quarter round on the top of the stringers so they can be wrapped propperly
drewmitch44
Next time i do it i might try just thin colth and a bunch of layers first then some thin matt and then some thin cloth and then some regular matt then the 24 oz roving i likt to use. Thats what ive done in the past. Once you get a couple of layers of cloth over it with no air its not that big of a problem. Then you can do whatever you want!
oops!
doesnt work....im doin .75 oz on an out side 90 deg corner. .......air.....glass doesnt like outside corners
drewpster
How do you vacuum bag a stringer?
Seems to me it would be possible to seal the bag directly to the inside of the hull in a single layer over the stringer. Then simply pull a vacuum drawing the bag down to the hull. I guess the hard part would be getting a good seal. Duct tape around the perimeter maybe? Then leave the pump running and use a plastic spreader to smooth out all the wrinkles? I would love it if somebody has a good process for this, I have some tall and long stringers. I'm thinking its gonna take a ton of work filleting all those inside corners.
