Capri 1750 Complete Restore :) & 9 Months to do it too!
Status
Not open for further replies.
dezmond
As in more like a dome than a beveled box ? I 'could' do that, but realize with only 22" of width you may not have much space for instrumentation if you go with too many curves. Possibly, I could round off the sides a bit . . . I'll see what I can do. My 'curved surface' skills on the software that I use are not a strong point :rolleyes:
Ya. Domed on the top and a nice arc to the back from the front.
tpenfield
This is about the best I can do . . . rounded the edges and re-tapered the portion in front of the windshield.
This was good practice for me in working with curves shapes. :)
I think you could start out with a basic design 'on paper' and then add curved shapes as you fabricate it.
tpenfield
I like Mad Props design, :thumb: particularly if you are going to have an aluminum tube supported windshield. Definitely would have to do a plug and mold with those curves.
Redtruck12
Can’t help much with the design partDez but if you willing to go for a bit of a drive there’s a couple boat salvage places in the Barrie area
Sandy Cove in Innisville would likely be the biggest
Inland in Georgina would be worth a look as well
a bit farther there is Kawartha Marine in Bobcaygoen
dezmond
K. Here’s the plan. I’m going to use all 3 designs in someway or another. tpenfield could you send me some dimensions on your final model you did? Different heights length width and over length? That would help me a ton to get the ball rolling. I owe you guys a ton! Thank you so much for helping me out. Now let’s make these ideas into a real console :)
tpenfield
The dimensions (foot print 22" x 42" ) were in the images, but I can add more dimensions, if that is what you are looking for. I would adjust them to your liking though . . .
tpenfield
Here are a couple of pictures with a bunch of dimensions. Feel free to round-off as needed.
I would make the kick plate removable for access and leave the sides smooth.
dezmond
Hey Everyone :)
Looooooooong overdue for an update and pics. Sorry been busy with RV Trade Shows and at the shop the last couple of weeks. BUT I did get lot's done on the boat and console over the last week and this weekend.
I took the design that tpenfield drew up and started to make the framework. Cut my base template first out of paper so I can get an idea and also something symmetrical to cut from.
Then cut it out of 1/2 Fir and cut my notches for my sticks. Sliced up some 1/2 sticks and sat down and started to put things together.
Also cut out my main console area and added those as well. Looking pretty good so far ;)
Then on to the cockpit area. Was a little more work back here to get the right angles and such but I figured it out. Front seat back is in as well.
Then the fun part. The dash ;) I took everything I could think I was putting on there and made cutouts to figure out how big I needed to go. Then I cut out the contour of the dash and laid out the templates to figure out where to put things...
All looks good so I grabbed the hole saws and cut away.. Did a temp fit on the gauges and voila!! That's where I am at today... I like what I see.
So next will be fastening the dash to the console somehow and then wrapping stretchy cloth on the top to get the shapes I am looking for. The main body of the console can be skinned with 1/8 ply I figure and then I will glass over that.
Sooooooooo.. Any input? Advice? Suggestions? Feedback?
Oh ya... I just gotta figure out where to put my switches, radio and Marine Radio... I'm sure I will find somewhere ;)
Thanks again guys for all the help ;)
Mechanicalmike08
That's looks pretty sweet. I would add some supports to the seat area to carry the load of a person. Just doesn't look like much from the pics.
you could add two bump outs on the lower section like under the tach and speedo for the switches. That way there a little closer to you and add some pizazz to the top.
tpenfield
Your woodworking skills are very impressive. I like how you did the instrumentation layout. :thumb:
plenty of room for switches under the gauges as well as room for cup holders
Status
