Capt Ron needs help
freddyray21
I don't find the site hard to use at all. First of all your post will get more responses if it is in the right forum. Your motor is a JW-10 3 1952-54 and should be run on 24:1 fuels mix. The carb probably need rebuilding and it is has not had the coils changed they probably need it too. the point gap is .020 and the plug gap is .035. change the impeller whether it is pumping water or not. If it's been sitting awhile or just been awhile since it has been changed there is a danger of it being brittle and breaking apart. clogging the lines or passages and overheating the motor.
